Saltar al contenido principal
Conair True Glow Lighted Mirror LED Bulb Replacement
Qué necesitas
  1. Conair True Glow Lighted Mirror LED Bulb Replacement, LED Bulb: paso 1, imagen 1 de 1
    • Unplug and remove batteries to make sure the ring light does not turn on while repairing.
  2. Conair True Glow Lighted Mirror LED Bulb Replacement: paso 2, imagen 1 de 3 Conair True Glow Lighted Mirror LED Bulb Replacement: paso 2, imagen 2 de 3 Conair True Glow Lighted Mirror LED Bulb Replacement: paso 2, imagen 3 de 3
    • Remove the two 2 mm screws on the side of the ring mirror (one on each side) using a Phillips #00 screwdriver.
  3. Conair True Glow Lighted Mirror LED Bulb Replacement: paso 3, imagen 1 de 1
    • Push the cover towards you and slide away from the rest of the mirror.
  4. Conair True Glow Lighted Mirror LED Bulb Replacement: paso 4, imagen 1 de 1
    • Using your hands, gently unscrew the old LED light bulb in a counter-clockwise direction.
  5. Conair True Glow Lighted Mirror LED Bulb Replacement: paso 5, imagen 1 de 1
    • Use your hands to screw in the new LED light bulb in a clockwise direction.
  6. Conair True Glow Lighted Mirror LED Bulb Replacement: paso 6, imagen 1 de 1
    • Take the cover and push it back down in place.
  7. Conair True Glow Lighted Mirror LED Bulb Replacement: paso 7, imagen 1 de 1
    • Screw in the two 2 mm screws on each side of the mirror using a Phillips #00 screwdriver.
  8. Conair True Glow Lighted Mirror LED Bulb Replacement: paso 8, imagen 1 de 1
    • Plug the mirror in and reinsert batteries to turn it on.
  9. Conair True Glow Lighted Mirror LED Bulb Replacement: paso 9, imagen 1 de 1
    • Enjoy your fixed LED ring mirror light!
Linea de Meta
Una persona más ha completado esta guía.
Dave Inthavong
Miembro Desde 01/19/21
216 Reputación
1 Guía escrita
Un comentario
What to do to get over to release. I’ve taken the screws out but cannot get the cover to release.
Bonnie Smith - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 18
Ultimos 30 días: 91
Todo El Tiempo: 2,466
