Saltar al contenido principal
Conair Infiniti Pro Model 259NP On/Off Button Replacement
Qué necesitas
  1. Conair Infiniti Pro Model 259NP On/Off Button Replacement, Back Panel: paso 1, imagen 1 de 1
    • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
    • Hold the hair dryer by the handle so that the back panel faces up.
  2. Conair Infiniti Pro Model 259NP On/Off Button Replacement: paso 2, imagen 1 de 2 Conair Infiniti Pro Model 259NP On/Off Button Replacement: paso 2, imagen 2 de 2
    • Remove the two 15.875 mm Phillips #2 screws from the back panel.
  3. Conair Infiniti Pro Model 259NP On/Off Button Replacement: paso 3, imagen 1 de 3 Conair Infiniti Pro Model 259NP On/Off Button Replacement: paso 3, imagen 2 de 3 Conair Infiniti Pro Model 259NP On/Off Button Replacement: paso 3, imagen 3 de 3
    • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
    • Continue separating the back panel, working along the seam.
    • With moderate force, completely remove the back panel from the hair dryer.
  4. Conair Infiniti Pro Model 259NP On/Off Button Replacement, Fan Motor Assembly: paso 4, imagen 1 de 2 Conair Infiniti Pro Model 259NP On/Off Button Replacement, Fan Motor Assembly: paso 4, imagen 2 de 2
    • Hold the hair dryer by the nozzle so that the handle points to the left.
    • Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
  5. Conair Infiniti Pro Model 259NP On/Off Button Replacement: paso 5, imagen 1 de 3 Conair Infiniti Pro Model 259NP On/Off Button Replacement: paso 5, imagen 2 de 3 Conair Infiniti Pro Model 259NP On/Off Button Replacement: paso 5, imagen 3 de 3
    • Caution: If you recently used the hair dryer, wait at least 10 minutes before attempting this step. The heating element may still be very hot and can cause serious burns.
    • Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
    • Lift the attached electrical wiring and heat shield completely out of the hair dryer.
  6. Conair Infiniti Pro Model 259NP On/Off Button Replacement, On/Off Button: paso 6, imagen 1 de 1
    • Caution: Do not attempt to open or tamper with the capacitor. You may suffer severe electrical shocks.
    • Hold the electrical switches so that the wires are facing upwards.
  7. Conair Infiniti Pro Model 259NP On/Off Button Replacement: paso 7, imagen 1 de 1
    • Focus on the button directly next to the cylindrical capacitor.
    • Desolder the button at the circled locations.
    • New line.
Conclusión
2 personas más completaron esta guía.
Timothy Lo
Miembro Desde 04/22/14
1,172 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 10-58, Amido Spring 2014 Miembro de Cal Poly, Team 10-58, Amido Spring 2014
CPSU-AMIDO-S14S10G58
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 14
Ultimos 30 días: 48
Todo El Tiempo: 7,865
