Saltar al contenido principal
Conair Infiniti PRO Curling Iron Heating Element Replacement
Qué necesitas
  1. Conair Infiniti PRO Curling Iron Heating Element Replacement, Housing: paso 1, imagen 1 de 1
    • Remove the Philips #1 28 mm.
    • Make sure device is unplugged and cool before attempting to replace parts.
  2. Conair Infiniti PRO Curling Iron Heating Element Replacement: paso 2, imagen 1 de 1
    • Remove the Philips #1 22 mm screws.
  3. Conair Infiniti PRO Curling Iron Heating Element Replacement: paso 3, imagen 1 de 3 Conair Infiniti PRO Curling Iron Heating Element Replacement: paso 3, imagen 2 de 3 Conair Infiniti PRO Curling Iron Heating Element Replacement: paso 3, imagen 3 de 3
    • Pry off the housing using a plastic spudger.
  4. Conair Infiniti PRO Curling Iron Heating Element Replacement, Power Cord: paso 4, imagen 1 de 1
    • Pull power chord out.
  5. Conair Infiniti PRO Curling Iron Heating Element Replacement, Motherboard: paso 5, imagen 1 de 1
    • Heat up your soldering gun and desolder the red wire from the motherboard as shown.
    • Note the location of wire attachment.
  6. Conair Infiniti PRO Curling Iron Heating Element Replacement: paso 6, imagen 1 de 1
    Herramienta utilizada en este paso:
    Desoldering Pump
    $3.99
    Comprar
    • With your soldering gun, desolder the white wire from the motherboard as shown.
  7. Conair Infiniti PRO Curling Iron Heating Element Replacement: paso 7, imagen 1 de 1
    • Once both wires are desoldered the motherboard can be removed.
  8. Conair Infiniti PRO Curling Iron Heating Element Replacement, Heating Element: paso 8, imagen 1 de 2 Conair Infiniti PRO Curling Iron Heating Element Replacement, Heating Element: paso 8, imagen 2 de 2
    • Remove the heating element mount. This will free up the heating element barrel for replacement.
Conclusión
3 personas más completaron esta guía.
Jonathon Bruer
Miembro Desde 11/09/17
607 Reputación
5 Guías creadas
Equipo
IUPUI, Team S7-G5, Baechle Fall 2017 Miembro de IUPUI, Team S7-G5, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 26
Todo El Tiempo: 1,555
