Saltar al contenido principal
Conair Cord-Keeper 169XR On/Off Switch Replacement
Qué necesitas
  1. Conair Cord-Keeper 169XR On/Off Switch Replacement, Handle Cover: paso 1, imagen 1 de 2 Conair Cord-Keeper 169XR On/Off Switch Replacement, Handle Cover: paso 1, imagen 2 de 2
    • Unscrew the two 18 mm long Phillips #2 screws on the side of the hair dryer.
  2. Conair Cord-Keeper 169XR On/Off Switch Replacement: paso 2, imagen 1 de 1
    • Be cautious of pieces that can possibly fall out when removing the face of the handle.
    • Once you have taken the screws out, take the top half of the handle off by lifting it off of the dryer.
  3. Conair Cord-Keeper 169XR On/Off Switch Replacement, On/Off Switch: paso 3, imagen 1 de 2 Conair Cord-Keeper 169XR On/Off Switch Replacement, On/Off Switch: paso 3, imagen 2 de 2
    • Now take out the On/Off switch by gently pulling it out towards you and lightly pushing it to the right with your finger until it comes out of the groove it is resting in.
    • Once the new switch is in place you can put the dryer back together.
Conclusión
3 personas más completaron esta guía.
Candace
Miembro Desde 01/23/14
992 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 10-33, Maness Winter 2014 Miembro de Cal Poly, Team 10-33, Maness Winter 2014
CPSU-MANESS-W14S10G33
3 Miembros
7 Guías creadas
3 comentarios
Looks to me that a replacement switch would be required. How can obtain one?
Jaky Felix - Contestar
“No parts required” is what’s displayed by default when there’s no link to an actual part for sale—it’’s a bit silly and clearly incorrect in this case. For hard-to-find parts, check eBay or Amazon. Also, a lot of folks with multiple broken units use these guides to cobble together one working unit from the parts. Good luck!
Jeff Suovanen -
That was my question, where can I get a replacement switch?
Constance Hudson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 29
Todo El Tiempo: 3,041
