Introducción
This guide details the replacement of the fan grille on the Conair Cord-Keeper 169XR. The fan grille of a hair dryer can sustain damage or dents when the dryer is dropped on the floor, leading to restricted airflow and uneven performance. Therefore, replacement is essential.
Before you begin, it is crucial to ensure that the hair dryer is turned off and unplugged. Additionally, be aware that hair dryers can become hot during operation. Thus, it is important to allow the dryer to cool down sufficiently to prevent burns.
During the removal of the handle cover in Step 2, exercise caution to prevent the spring from falling out. The loss of the spring could render the dryer unusable.
In Step 10, you will need to remove the coil from the back of the hair dryer. Handle the coil with care and take measures to prevent it from unwinding completely. It can be challenging to wind it back during reassembly if it becomes fully unwound during the removal process.
Qué necesitas
Unscrew the two 18 mm long Phillips #2 screws on the side of the hair dryer.
Remove the inner white disk piece by gently pulling it out with your finger nail.
On the back of the dryer, remove the white plastic piece so the wires don't get caught.
