Saltar al contenido principal
Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement
Qué necesitas
  1. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement, Handle Cover: paso 1, imagen 1 de 2 Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement, Handle Cover: paso 1, imagen 2 de 2
    • Unscrew the two 18 mm long Phillips #2 screws on the side of the hair dryer.
  2. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: paso 2, imagen 1 de 1
    • Be cautious of pieces that can possibly fall out when removing the face of the handle.
    • Once you have taken the screws out, take the top half of the handle off by lifting it off of the dryer.
  3. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement, Dryer Head: paso 3, imagen 1 de 2 Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement, Dryer Head: paso 3, imagen 2 de 2
    • Remove the inner white disk piece by gently pulling it out with your finger nail.
  4. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: paso 4, imagen 1 de 3 Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: paso 4, imagen 2 de 3 Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: paso 4, imagen 3 de 3
    • Gently remove the tan boxes (power supply) by wiggling them out of place and set them aside so you can take the back part of the handle off.
  5. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: paso 5, imagen 1 de 2 Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: paso 5, imagen 2 de 2
    • Remove the inner white disk piece from the base of the dryer head by gently pulling it out with your finger nail.
  6. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: paso 6, imagen 1 de 1
    • Unscrew the three 12 mm long Phillips #2 screws to remove the back of the hairdryer.
  7. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: paso 7, imagen 1 de 1
    • Once the three screws are removed, pop the back of the dryer off by wiggling it until it comes loose. This shouldn't take too much effort.
  8. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: paso 8, imagen 1 de 2 Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: paso 8, imagen 2 de 2
    • Unwind the cord and lay it to the side so you can get to the screw in the middle easier.
    • Remove the single 12 mm long Phillips #2 screw in the middle of the cord track.
  9. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: paso 9, imagen 1 de 2 Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: paso 9, imagen 2 de 2
    • Take off the white cap that covers the heating coil. You will see a wound up piece of metal (cord retracting coil) underneath once the cap is removed.
  10. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: paso 10, imagen 1 de 2 Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: paso 10, imagen 2 de 2
    • When removing the coil, make sure it stays wound up. It could very easily pop out, and you would have to wind it all the way back up and try to squeeze it back into the slot when you reassemble the dryer.
    • To remove the coil, use your screw driver to pop the coil out of the slot.
    • The second image is what the coil would look like if it came undone when you removed it.
  11. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: paso 11, imagen 1 de 3 Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: paso 11, imagen 2 de 3 Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: paso 11, imagen 3 de 3
    • Once the coil is removed, unscrew the three 11 mm long Phillips #2 screws underneath to remove the retracting wheel.
  12. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement, Cord Retracting Mechanism: paso 12, imagen 1 de 2 Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement, Cord Retracting Mechanism: paso 12, imagen 2 de 2
    • Remove the two parts of the retracting wheel.
Conclusión
2 personas más completaron esta guía.
Candace
Miembro Desde 01/23/14
1,010 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 10-33, Maness Winter 2014 Miembro de Cal Poly, Team 10-33, Maness Winter 2014
CPSU-MANESS-W14S10G33
Miembros de 3
14 Guías creadas
2Guía Comentarios
Nicely done, just a suggestion, in Step #10 would suggest using fingers or flat object on top of spring when disengaging from frame …to ensure it won’t unravel and jump (as shown in 2nd picture + have some strong tape, string, wire ties, etc. to keep the spring wound up. This works for me when dealing with lawn mower recoil mechanism or tape measures. Tape measures are the worst to work on. lol - AHNauss
Howard - Contestar
Wind cord up around handle put in drawer done. All that and it will inevitably fail again. Stupid design
R J Enoel - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 45
Todo El Tiempo: 7,057
