Saltar al contenido principal
Conair Cord-Keeper 169XR Cord Retracting Button Replacement
Qué necesitas
  1. Conair Cord-Keeper 169XR Cord Retracting Button Replacement, Handle Cover: paso 1, imagen 1 de 2 Conair Cord-Keeper 169XR Cord Retracting Button Replacement, Handle Cover: paso 1, imagen 2 de 2
    • Unscrew the two 18 mm long Phillips #2 screws on the side of the hair dryer.
  2. Conair Cord-Keeper 169XR Cord Retracting Button Replacement: paso 2, imagen 1 de 1
    • Be cautious of pieces that can possibly fall out when removing the face of the handle.
    • Once you have taken the screws out, take the top half of the handle off by lifting it off of the dryer.
  3. Conair Cord-Keeper 169XR Cord Retracting Button Replacement, Dryer Head: paso 3, imagen 1 de 2 Conair Cord-Keeper 169XR Cord Retracting Button Replacement, Dryer Head: paso 3, imagen 2 de 2
    • Remove the inner white disk piece by gently pulling it out with your finger nail.
  4. Conair Cord-Keeper 169XR Cord Retracting Button Replacement: paso 4, imagen 1 de 3 Conair Cord-Keeper 169XR Cord Retracting Button Replacement: paso 4, imagen 2 de 3 Conair Cord-Keeper 169XR Cord Retracting Button Replacement: paso 4, imagen 3 de 3
    • Gently remove the tan boxes (power supply) by wiggling them out of place and set them aside so you can take the back part of the handle off.
  5. Conair Cord-Keeper 169XR Cord Retracting Button Replacement: paso 5, imagen 1 de 2 Conair Cord-Keeper 169XR Cord Retracting Button Replacement: paso 5, imagen 2 de 2
    • Remove the inner white disk piece from the base of the dryer head by gently pulling it out with your finger nail.
  6. Conair Cord-Keeper 169XR Cord Retracting Button Replacement: paso 6, imagen 1 de 1
    • Unscrew the three 12 mm long Phillips #2 screws to remove the back of the hairdryer.
  7. Conair Cord-Keeper 169XR Cord Retracting Button Replacement: paso 7, imagen 1 de 1
    • Once the three screws are removed, pop the back of the dryer off by wiggling it until it comes loose. This shouldn't take too much effort.
  8. Conair Cord-Keeper 169XR Cord Retracting Button Replacement: paso 8, imagen 1 de 2 Conair Cord-Keeper 169XR Cord Retracting Button Replacement: paso 8, imagen 2 de 2
    • Unwind the cord and lay it to the side so you can get to the screw in the middle easier.
    • Remove the single 12 mm long Phillips #2 screw in the middle of the cord track.
  9. Conair Cord-Keeper 169XR Cord Retracting Button Replacement: paso 9, imagen 1 de 2 Conair Cord-Keeper 169XR Cord Retracting Button Replacement: paso 9, imagen 2 de 2
    • Take off the white cap that covers the heating coil. You will see a wound up piece of metal (cord retracting coil) underneath once the cap is removed.
  10. Conair Cord-Keeper 169XR Cord Retracting Button Replacement: paso 10, imagen 1 de 2 Conair Cord-Keeper 169XR Cord Retracting Button Replacement: paso 10, imagen 2 de 2
    • When removing the coil, make sure it stays wound up. It could very easily pop out, and you would have to wind it all the way back up and try to squeeze it back into the slot when you reassemble the dryer.
    • To remove the coil, use your screw driver to pop the coil out of the slot.
    • The second image is what the coil would look like if it came undone when you removed it.
  11. Conair Cord-Keeper 169XR Cord Retracting Button Replacement: paso 11, imagen 1 de 3 Conair Cord-Keeper 169XR Cord Retracting Button Replacement: paso 11, imagen 2 de 3 Conair Cord-Keeper 169XR Cord Retracting Button Replacement: paso 11, imagen 3 de 3
    • Once the coil is removed, unscrew the three 11 mm long Phillips #2 screws underneath to remove the retracting wheel.
  12. Conair Cord-Keeper 169XR Cord Retracting Button Replacement, Cord Retracting Button: paso 12, imagen 1 de 3 Conair Cord-Keeper 169XR Cord Retracting Button Replacement, Cord Retracting Button: paso 12, imagen 2 de 3 Conair Cord-Keeper 169XR Cord Retracting Button Replacement, Cord Retracting Button: paso 12, imagen 3 de 3
    • Once the retracting wheel is off, you can get to the retracting button and gently remove it by pulling it out of the groove it is resting in.
    • Now you just need to replace it with a new one. (The stem of your button may have broken and stopped activating the retracting wheel).
Conclusión
Candace
Miembro Desde 01/23/14
992 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 10-33, Maness Winter 2014 Miembro de Cal Poly, Team 10-33, Maness Winter 2014
CPSU-MANESS-W14S10G33
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 30
Todo El Tiempo: 4,363
