Saltar al contenido principal
Conair Cord-Keeper 169XR Cool Down Button Replacement
Qué necesitas
  1. Conair Cord-Keeper 169XR Cool Down Button Replacement, Handle Cover: paso 1, imagen 1 de 2 Conair Cord-Keeper 169XR Cool Down Button Replacement, Handle Cover: paso 1, imagen 2 de 2
    • Unscrew the two 18 mm long Phillips #2 screws on the side of the hair dryer.
  2. Conair Cord-Keeper 169XR Cool Down Button Replacement: paso 2, imagen 1 de 1
    • Be cautious of pieces that can possibly fall out when removing the face of the handle.
    • Once you have taken the screws out, take the top half of the handle off by lifting it off of the dryer.
  3. Conair Cord-Keeper 169XR Cool Down Button Replacement, Cool Down Button: paso 3, imagen 1 de 2 Conair Cord-Keeper 169XR Cool Down Button Replacement, Cool Down Button: paso 3, imagen 2 de 2
    • Take out the cool down button and the spring behind it by gently lifting the button up toward you and pushing it to the right out of its groove.
    • You may need to replace the button and spring depending on which one is broken.
Conclusión
Una persona más ha completado esta guía.
Candace
Miembro Desde 01/23/14
992 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 10-33, Maness Winter 2014 Miembro de Cal Poly, Team 10-33, Maness Winter 2014
CPSU-MANESS-W14S10G33
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 17
Todo El Tiempo: 1,286
