Saltar al contenido principal
Computer King Muffin Kinder 7 Logic Board Replacement
Qué necesitas
  1. Computer King Muffin Kinder 7 Logic Board Replacement, Logic Board: paso 1, imagen 1 de 2 Computer King Muffin Kinder 7 Logic Board Replacement, Logic Board: paso 1, imagen 2 de 2
    • Use the plastic opening tool help push out the microSD card from the microSD slot.
  2. Computer King Muffin Kinder 7 Logic Board Replacement: paso 2, imagen 1 de 1
    • Use the plastic opening tool to unclip the plastic front from the plastic back. Use the MicroSD slot to initially start the unclipping.
  3. Computer King Muffin Kinder 7 Logic Board Replacement: paso 3, imagen 1 de 2 Computer King Muffin Kinder 7 Logic Board Replacement: paso 3, imagen 2 de 2
    • Unscrew the nine 3.0 mm Phillips #00 screws.
  4. Computer King Muffin Kinder 7 Logic Board Replacement: paso 4, imagen 1 de 1
    • The battery is glued onto the black plastic. Use the plastic opening tool to pry the battery from the black plastic
  5. Computer King Muffin Kinder 7 Logic Board Replacement: paso 5, imagen 1 de 3 Computer King Muffin Kinder 7 Logic Board Replacement: paso 5, imagen 2 de 3 Computer King Muffin Kinder 7 Logic Board Replacement: paso 5, imagen 3 de 3
    • Unsolder the 11 red, back, and grey wires connected to the logic board.
    • Tips on how to solder can be found here.
  6. Computer King Muffin Kinder 7 Logic Board Replacement: paso 6, imagen 1 de 3 Computer King Muffin Kinder 7 Logic Board Replacement: paso 6, imagen 2 de 3 Computer King Muffin Kinder 7 Logic Board Replacement: paso 6, imagen 3 de 3
    • Use the flat end of the spudger to lift the black panels covering the three ribbon cables connected to the logic board.
  7. Computer King Muffin Kinder 7 Logic Board Replacement: paso 7, imagen 1 de 1
    • Pull the three ribbon cables out so that they are no longer connected to the logic board.
Conclusión
Una persona más ha completado esta guía.
Katherine
Miembro Desde 01/22/15
439 Reputación
3 Guías creadas
Equipo
UWT Liner: Group 2 Miembro de UWT Liner: Group 2
Community
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 234
