Saltar al contenido principal
Compaq iPAQ Pocket PC 3830 Battery Replacement
Qué necesitas
  1. Compaq iPAQ Pocket PC 3830 Battery Replacement, Remove four screws from back cover: paso 1, imagen 1 de 2 Compaq iPAQ Pocket PC 3830 Battery Replacement, Remove four screws from back cover: paso 1, imagen 2 de 2
    • Remove the four 0.8 mm Phillips #00 screws from the back cover.
  2. Compaq iPAQ Pocket PC 3830 Battery Replacement: paso 2, imagen 1 de 1
    • Detach the yellow wire from comb that is attached to the battery.
  3. Compaq iPAQ Pocket PC 3830 Battery Replacement: paso 3, imagen 1 de 1
    • The yellow wire is removed from the comb attached to the battery.
  4. Compaq iPAQ Pocket PC 3830 Battery Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Remove the battery using tweezers from back cover.
  5. Compaq iPAQ Pocket PC 3830 Battery Replacement: paso 5, imagen 1 de 1
    • Detach the battery from back cover.
Conclusión
3 personas más completaron esta guía.
Sedina Cavcic
Miembro Desde 09/05/14
464 Reputación
3 Guías creadas
Equipo
2 comentarios
One question; Where can I get a new battery????
Every place I have looked have a smaller batter,  not like the one you show.
Stephen
oharasc85@gmail.com
Stephen O'Hara - Contestar
we are in need of battery
Danionics DLP 305590
Quantity : 02 Nos.
Please send us the lowest estimate.
Mail ID: electronics@pmtpims.org
ELECTRONICS1 PIMS - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 31
Todo El Tiempo: 3,227
