Partes
No se requieren partes.
  1. Remove the battery before starting
    • Remove the battery before starting
  2. Loosen the two screw for the hard drive cover
    • Loosen the two screw for the hard drive cover
    • The screws will stay attached the the cover
    • Lift the cover from the left side and remove
    • Lift the black pull tab on the hard drive
    • Lift the drive straight up out of the laptop
    • Remove the four screws on the sides of the drive (two on each side)
    • Remove the hard drive from the caddy
    • Pull the IDE connecter straight off the drive
    • Be sure to pull the connecter off straight so as not to bend the hard drive IDE pins
Conclusión
4 personas más completaron esta guía.
Andrew
Miembro Desde 08/05/10
1,164 Reputación
5 Guías creadas
Perfect instructions....easy directions even for a computer dunce like me...
John Platania - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 13
Últimos 30 Días: 63
Todo El Tiempo: 6,776
