Saltar al contenido principal
Compaq Presario V2414NR WiFi Card Replacement
Qué necesitas
  1. Compaq Presario V2414NR WiFi Card Replacement, Battery: paso 1, imagen 1 de 1
    • Shutdown the computer.
    • Remove all external devices.
    • Unplug the power, and any other cords, from the laptop.
    • Turn the laptop upside down, with the front towards you.
  2. Compaq Presario V2414NR WiFi Card Replacement: paso 2, imagen 1 de 2 Compaq Presario V2414NR WiFi Card Replacement: paso 2, imagen 2 de 2
    • Slide the battery release latch to the left until the battery pops up.
    • Lift the front edge of the battery pack and swing it back to remove it.
    • When reassembling, first align the back of the battery with the chassis, then press the front downwards until it latches.
  3. Compaq Presario V2414NR WiFi Card Replacement, RAM Cover: paso 3, imagen 1 de 2 Compaq Presario V2414NR WiFi Card Replacement, RAM Cover: paso 3, imagen 2 de 2
    • Loosen the two 5mm Phillips #1 screws that secure the memory module compartment cover to the computer.
    • These screws are captured to the cover panel.
    • Lift the front edge of the memory module compartment cover and swing it back to remove it.
  4. Compaq Presario V2414NR WiFi Card Replacement, WiFi Card: paso 4, imagen 1 de 2 Compaq Presario V2414NR WiFi Card Replacement, WiFi Card: paso 4, imagen 2 de 2
    • Loosen the 5mm Phillips #1 screw that secures the Mini PCI compartment cover to the computer.
    • This screw is captured to the cover panel.
    • Lift the rear edge of the Mini PCI compartment cover, and swing it forward to remove it.
  5. Compaq Presario V2414NR WiFi Card Replacement: paso 5, imagen 1 de 2 Compaq Presario V2414NR WiFi Card Replacement: paso 5, imagen 2 de 2
    • Make note of which cable is attached to which clip on the WiFi card before disconnecting the cables.
    • Disconnect the wireless antenna cables from the WiFi card by prying gently upwards on the metal part of the connector with a spudger or plastic opening tool.
  6. Compaq Presario V2414NR WiFi Card Replacement: paso 6, imagen 1 de 2 Compaq Presario V2414NR WiFi Card Replacement: paso 6, imagen 2 de 2
    • Use your fingernails, or plastic opening tools, to spread the metal retaining tabs on each side of the WiFi card outwards until the card pops up.
    • Pull the WiFi card out of the socket at the same angle it is now oriented.
    • When reassembling, align the offset notch on the WiFi card contacts with the tab on the socket and insert at a 30 degree angle.
Conclusión
Rylie Schmidt
Miembro Desde 04/19/15
765 Reputación
7 Guías creadas
Equipo
UMass Dartmouth, Team 2-1, Isaacson Fall 2016 Miembro de UMass Dartmouth, Team 2-1, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G1
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 13
Todo El Tiempo: 325
