Introducción
RAM is a crucial component which attributes to the speed and multitasking ability of the computer.
Qué necesitas
Shutdown the computer.
Remove all external devices.
Unplug the power, and any other cords, from the laptop.
Turn the laptop upside down, with the front towards you.
Loosen the two 5mm Phillips #1 screws that secure the memory module compartment cover to the computer.
Lift the front edge of the memory module compartment cover and swing it back to remove it.
Use your fingers, or plastic opening tools, to spread the metal retaining tabs on each side of the RAM outwards until the module pops up.
Pull the module out of the socket at the same angle it is now oriented.
Repeat these steps to remove the second memory module.
