Saltar al contenido principal
Compaq Presario V2414NR RAM Replacement
Qué necesitas
  1. Compaq Presario V2414NR RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Shutdown the computer.
    • Remove all external devices.
    • Unplug the power, and any other cords, from the laptop.
    • Turn the laptop upside down, with the front towards you.
  2. Compaq Presario V2414NR RAM Replacement: paso 2, imagen 1 de 2 Compaq Presario V2414NR RAM Replacement: paso 2, imagen 2 de 2
    • Slide the battery release latch to the left until the battery pops up.
    • Lift the front edge of the battery pack and swing it back to remove it.
    • When reassembling, first align the back of the battery with the chassis, then press the front downwards until it latches.
  3. Compaq Presario V2414NR RAM Replacement, RAM Cover: paso 3, imagen 1 de 2 Compaq Presario V2414NR RAM Replacement, RAM Cover: paso 3, imagen 2 de 2
    • Loosen the two 5mm Phillips #1 screws that secure the memory module compartment cover to the computer.
    • These screws are captured to the cover panel.
    • Lift the front edge of the memory module compartment cover and swing it back to remove it.
  4. Compaq Presario V2414NR RAM Replacement, RAM: paso 4, imagen 1 de 2 Compaq Presario V2414NR RAM Replacement, RAM: paso 4, imagen 2 de 2
    • Use your fingers, or plastic opening tools, to spread the metal retaining tabs on each side of the RAM outwards until the module pops up.
    • Pull the module out of the socket at the same angle it is now oriented.
    • Repeat these steps to remove the second memory module.
    • When reassembling, align the offset notch on the RAM contacts with the tab on the socket and insert at a 30 degree angle.
Conclusión
Rylie Schmidt
Miembro Desde 04/19/15
765 Reputación
7 Guías creadas
Equipo
UMass Dartmouth, Team 2-1, Isaacson Fall 2016 Miembro de UMass Dartmouth, Team 2-1, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G1
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 11
Todo El Tiempo: 239
