Saltar al contenido principal
Compaq Mini 110 Screen Replacement
Qué necesitas
  1. Compaq Mini 110 Screen Replacement, Battery: paso 1, imagen 1 de 2 Compaq Mini 110 Screen Replacement, Battery: paso 1, imagen 2 de 2
    • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
  2. Compaq Mini 110 Screen Replacement: paso 2, imagen 1 de 3 Compaq Mini 110 Screen Replacement: paso 2, imagen 2 de 3 Compaq Mini 110 Screen Replacement: paso 2, imagen 3 de 3
    • Push both tabs inward simultaneously and slide the battery out.
  3. Compaq Mini 110 Screen Replacement, RAM: paso 3, imagen 1 de 2 Compaq Mini 110 Screen Replacement, RAM: paso 3, imagen 2 de 2
    • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
  4. Compaq Mini 110 Screen Replacement: paso 4, imagen 1 de 1
    • Push out the side tabs simultaneously and pull out the old RAM module.
    • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
  5. Compaq Mini 110 Screen Replacement, Keyboard: paso 5, imagen 1 de 2 Compaq Mini 110 Screen Replacement, Keyboard: paso 5, imagen 2 de 2
    • Remove the rubber pads located on the corners of your Compaq Mini.
    • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
  6. Compaq Mini 110 Screen Replacement: paso 6, imagen 1 de 2 Compaq Mini 110 Screen Replacement: paso 6, imagen 2 de 2
    • Unscrew all the corner screws. There are four total, one under each rubber pad.
  7. Compaq Mini 110 Screen Replacement: paso 7, imagen 1 de 2 Compaq Mini 110 Screen Replacement: paso 7, imagen 2 de 2
    • Unscrew the screw for the bottom case located in the RAM compartment.
  8. Compaq Mini 110 Screen Replacement: paso 8, imagen 1 de 2 Compaq Mini 110 Screen Replacement: paso 8, imagen 2 de 2
    • Remove the three screws in the silver tabs at the back of the keyboard.
    • These are located at the back of the base under the screen.
    • Lift the keyboard away from the laptop.
  9. Compaq Mini 110 Screen Replacement, Hard Drive: paso 9, imagen 1 de 1
    • Remove the three screws holding the panel in place.
  10. Compaq Mini 110 Screen Replacement: paso 10, imagen 1 de 2 Compaq Mini 110 Screen Replacement: paso 10, imagen 2 de 2
    • Pull up on the tab to remove the hard drive.
  11. Compaq Mini 110 Screen Replacement, Top Cover: paso 11, imagen 1 de 1
    • Remove the eight screws that are from the plastic top cover.
  12. Compaq Mini 110 Screen Replacement: paso 12, imagen 1 de 3 Compaq Mini 110 Screen Replacement: paso 12, imagen 2 de 3 Compaq Mini 110 Screen Replacement: paso 12, imagen 3 de 3
    • Pry up the top plastic cover using a spudger.
    • These two tabs under the screen need to be pushed in with a spudger.
  13. Compaq Mini 110 Screen Replacement: paso 13, imagen 1 de 2 Compaq Mini 110 Screen Replacement: paso 13, imagen 2 de 2
    • Remove the cable by carefully pulling it up.
    • Be careful when lifting up the cover because the track pad is still attached.
  14. Compaq Mini 110 Screen Replacement, Display Assembly: paso 14, imagen 1 de 3 Compaq Mini 110 Screen Replacement, Display Assembly: paso 14, imagen 2 de 3 Compaq Mini 110 Screen Replacement, Display Assembly: paso 14, imagen 3 de 3
    • Remove the four screws that keep the bottom of the hinges attached to the base.
  15. Compaq Mini 110 Screen Replacement: paso 15, imagen 1 de 3 Compaq Mini 110 Screen Replacement: paso 15, imagen 2 de 3 Compaq Mini 110 Screen Replacement: paso 15, imagen 3 de 3
    • Pry off the top plastic cover of the display assembly.
    • The spudger may go all the way through to the screen-side of the cover. This is not a problem and won't damage anything.
    • There is adhesive tape holding the cover on.
  16. Compaq Mini 110 Screen Replacement, Screen: paso 16, imagen 1 de 3 Compaq Mini 110 Screen Replacement, Screen: paso 16, imagen 2 de 3 Compaq Mini 110 Screen Replacement, Screen: paso 16, imagen 3 de 3
    • Remove the 4 screws keeping the screen on the plastic assembly.
  17. Compaq Mini 110 Screen Replacement: paso 17, imagen 1 de 3 Compaq Mini 110 Screen Replacement: paso 17, imagen 2 de 3 Compaq Mini 110 Screen Replacement: paso 17, imagen 3 de 3
    • Take the screen off the metal connectors by unscrewing each side. Each side has 2 screws.
    • The last picture shows the metal connectors that attach it to the display assembly.
  18. Compaq Mini 110 Screen Replacement: paso 18, imagen 1 de 3 Compaq Mini 110 Screen Replacement: paso 18, imagen 2 de 3 Compaq Mini 110 Screen Replacement: paso 18, imagen 3 de 3
    • Detach the cable from the screen. It is connected under the foil flap.
    • The large wire on the back of the screen is for both the webcam and the microphone, as well as the screen.
Conclusión
Una persona más ha completado esta guía.
alea
Miembro Desde 10/06/10
1,405 Reputación
14 Guías creadas
Equipo
Cal Poly, Team 22-2, Maness Fall 2010 Miembro de Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 10
Ultimos 30 días: 14
Todo El Tiempo: 11,488
