Saltar al contenido principal
Compaq Evo N1000v Rear Fan Replacement
Qué necesitas
  1. Compaq Evo N1000v Rear Fan Replacement, Rear Fan: paso 1, imagen 1 de 1
    • Carefully remove the screws located inside the red circles.
  2. Compaq Evo N1000v Rear Fan Replacement: paso 2, imagen 1 de 2 Compaq Evo N1000v Rear Fan Replacement: paso 2, imagen 2 de 2
    • Next, you will need to push down the "F1" key with the spudger and push it under the silver LED display panel.
    • Push down on the spudger to lift the LED display upward.
    • Do this on both the left and right sides of the device as shown in the images.
  3. Compaq Evo N1000v Rear Fan Replacement: paso 3, imagen 1 de 1
    • Completely remove the LED display panel from the device.
  4. Compaq Evo N1000v Rear Fan Replacement: paso 4, imagen 1 de 1
    • Lift the keyboard up from the back end as shown in the image.
  5. Compaq Evo N1000v Rear Fan Replacement: paso 5, imagen 1 de 1
    • Pull the keyboard slightly toward the screen of the device to reveal the connecting cable below.
  6. Compaq Evo N1000v Rear Fan Replacement: paso 6, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Follow the cable to its connection and use the grip tweezers to unlock the cable by grabbing the left side of the lock and pulling upward.
    • Repeat this action on the right side of the lock.
  7. Compaq Evo N1000v Rear Fan Replacement: paso 7, imagen 1 de 1
    • Pull the keyboard upward to remove it from the device.
  8. Compaq Evo N1000v Rear Fan Replacement: paso 8, imagen 1 de 1
    • Unscrew the 3 screws as shown in the photo.
  9. Compaq Evo N1000v Rear Fan Replacement: paso 9, imagen 1 de 1
    • Remove the cable with the grip tweezers as shown in the photo.
  10. Compaq Evo N1000v Rear Fan Replacement: paso 10, imagen 1 de 1
    • Remove the rear fan.
    • Repeat these steps in reverse order to install the new rear fan.
Conclusión
Una persona más ha completado esta guía.
ryan
Miembro Desde 03/12/14
470 Reputación
2 Guías creadas
Equipo
Un comentario
My Big Thanks! I cleaned the radiator, cooler greased and replaced the thermal grease from the CPU and GPU.
DeK-Test New - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 429
