Saltar al contenido principal
Compaq Evo N1000v Palm Rest Replacement
Qué necesitas
  1. Compaq Evo N1000v Palm Rest Replacement, LED Cover: paso 1, imagen 1 de 1
    • Flip the laptop over with the rear panel facing forward.
  2. Compaq Evo N1000v Palm Rest Replacement: paso 2, imagen 1 de 1
    • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
  3. Compaq Evo N1000v Palm Rest Replacement: paso 3, imagen 1 de 1
    • Flip the laptop back over with the front facing forward. Open the screen.
  4. Compaq Evo N1000v Palm Rest Replacement: paso 4, imagen 1 de 1
    • Locate the F1 and F2 keys near the top left corner of the keyboard.
  5. Compaq Evo N1000v Palm Rest Replacement: paso 5, imagen 1 de 1
    • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  6. Compaq Evo N1000v Palm Rest Replacement: paso 6, imagen 1 de 1
    • Locate the Scroll and Pause keys near the top right corner of the keyboard.
  7. Compaq Evo N1000v Palm Rest Replacement: paso 7, imagen 1 de 1
    • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  8. Compaq Evo N1000v Palm Rest Replacement: paso 8, imagen 1 de 2 Compaq Evo N1000v Palm Rest Replacement: paso 8, imagen 2 de 2
    • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
  9. Compaq Evo N1000v Palm Rest Replacement, Keyboard: paso 9, imagen 1 de 1
    • Lift the back edge of the keyboard and pull towards the screen.
  10. Compaq Evo N1000v Palm Rest Replacement: paso 10, imagen 1 de 1
    • Pull the cable and lift up to release.
  11. Compaq Evo N1000v Palm Rest Replacement: paso 11, imagen 1 de 1
    • Remove the keyboard.
  12. Compaq Evo N1000v Palm Rest Replacement, Palm Rest: paso 12, imagen 1 de 1
    • Close the laptop and flip it so the rear panel is facing up.
  13. Compaq Evo N1000v Palm Rest Replacement: paso 13, imagen 1 de 1
    • Using the TR8 Torx screwdriver, remove the six screws from the back case.
  14. Compaq Evo N1000v Palm Rest Replacement: paso 14, imagen 1 de 1
    • Remove the battery.
    • Remove the screw from the metal support on the case edge with a Torx T8 screwdriver.
    • Flip the laptop over again so the top is facing up.
    • Open the laptop screen and face it towards you.
  15. Compaq Evo N1000v Palm Rest Replacement: paso 15, imagen 1 de 1
    • Lift the the palm rest up from the front edge of the laptop and swing it towards the screen.
    • Be gentle as it is connected by some cables.
  16. Compaq Evo N1000v Palm Rest Replacement: paso 17, imagen 1 de 1
    • Disconnect the second ribbon cable.
  17. Compaq Evo N1000v Palm Rest Replacement: paso 18, imagen 1 de 1
    • Remove the palm rest.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 29-74, Johann Spring 2010 Miembro de Cal Poly, Team 29-74, Johann Spring 2010
CPSU-JOHANN-S10S29G74
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 3,095
