Introducción
The powertrain assembly is comprised of the motor, the gearbox, and the transfer gears. Unlike previous generations of KitchenAid AC Motor bowl-lift mixers, which had these broken in to discrete parts, this is a single unit in this model and must be replaced as such.
Note: Depending on the generation of your motor it might have a different coloration than the one in the picture (e.g. older models were all silver). Verify the motor part number before continuing.
Qué necesitas
Using a #2 Philips Screwdriver, remove the screw which holds on the trim band.
Remove the trim band.
Remove the four screws (circled in yellow, two on each side) using a #2 Philips Screwdriver
Remove the motor housing by lifting it straight up.
Place a couple dish towels or other soft materials on the base to protect it from any potential impact.
Disconnect the planetary from the motor drive shaft by removing the retaining pin (circled in yellow). You can do this with a hammer and either a pin punch or a Torx T15 screwdriver. Simply hammer the punch/screwdriver on the pin until it comes out the other side.
If the planetary assembly doesn't fall out, you might have to give it a firm pull straight down to remove it.
Using a #2 Phillips Screwdriver, remove the four screws (circled in yellow).
There are two motor support brackets: one in front, one back (shown in the first image)
Each bracket is attached to the motor by two screws (one on each side).
Using a #2 Phillips screwdriver, remove the four screws (circled in yblue in the second and third images) which attach the two motor support brackets.
Disconnect the motor power cable by depressing the locking tab (circled in yellow) while pulling the connector apart.
Using a #2 Philips screwdriver, remove the four screws (indicated in yellow, two on each side) attaching the powertrain/motor to the mixer body.
Remove the hall effect sensor from its mount by pressing down on the tab indicated in the first picture and sliding it out.
Now that the powertrain/motor is fully disconnected from the mixer, remove it and place it to the side.
Begin the reassembly process with the new powertrain/motor
