Saltar al contenido principal
Comfort Zone CZ6C Fan Blades Replacement
Qué necesitas
  1. Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: paso 1, imagen 1 de 3 Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: paso 1, imagen 2 de 3 Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: paso 1, imagen 3 de 3
    • The metal cage is kept in place by three plastic tabs on the plastic body. Focus your pulling around these tabs to make the job easier.
    • In order to remove the metal cage, place one hand firmly on the back plastic body and your other hand on the metal cage.
    • Now work your way around the edge of the fan cage and pull it away from the plastic body.
  2. Comfort Zone CZ6C Fan Blades Replacement: paso 2, imagen 1 de 2 Comfort Zone CZ6C Fan Blades Replacement: paso 2, imagen 2 de 2
    • To remove the fan blade, reach behind it and slowly pull it towards you.
    • If the fan blade axle has any hair or dirt, then clean it with a cloth to avoid further fan blade blockage.
    • If you are having difficulty removing the fan blade, then generously apply WD-40 to the fan blade axle.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 17-5, Forte Spring 2015 Miembro de Cal Poly, Team 17-5, Forte Spring 2015
CPSU-FORTE-S15S17G5
Miembros de 4
5 Guías creadas
2 comentarios
Where does one buy the replacement blades?
Frank Gould - Contestar
where does one buy the replacement blades??
Luis Marrero - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 5,990
