Saltar al contenido principal
How to clean the Shure SM58
Qué necesitas
  1. How to clean the Shure SM58, Collar: paso 1, imagen 1 de 3 How to clean the Shure SM58, Collar: paso 1, imagen 2 de 3 How to clean the Shure SM58, Collar: paso 1, imagen 3 de 3
    • Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it.
    • Be careful to not pull on the collar or you may rip the wires from the faceplate.
  2. How to clean the Shure SM58, How to clean the Shure SM58: paso 2, imagen 1 de 1
    • Create a mild cleaning solution by mixing a few drops of dish soap and water in a cup.
    • Using a detailing brush and the solution, gently brush the pins and inside walls of the microphone.
  3. How to clean the Shure SM58: paso 3, imagen 1 de 1
    • Make sure connector is completely dry before soldering, failure to do so may result in permanent damage.
    • If you have previously soldered inside the microphone, you may use a soldering iron to melt off any excess solder that may be on the pins inside the connector. Do not attempt this if you have never soldered on the microphone before.
Conclusión
After cleaning the faceplate and reassembling the microphone, it should work at its maximum potential.
Una persona más ha completado esta guía.
nat coll
Miembro Desde 09/27/12
721 Reputación
14 Guías creadas
Equipo
Cal Poly, Team 7-53, Forte Fall 2012 Miembro de Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
Miembros de 5
30 Guías creadas
2 comentarios
Thanks for the join. I’m checking out the Shure Sm-58 repair. Thanks for the info
Mike gallagher - Contestar
Hi I checked the solder on the wires inside the microphone and it still does not work. Any other ideas?
karl_ivers - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 68
Todo El Tiempo: 11,045
