Saltar al contenido principal
ComNet Ericsson Panther 600P Speaker Replacement
Qué necesitas
  1. ComNet Ericsson Panther 600P Speaker Replacement, Locate the release button.: paso 1, imagen 1 de 3 ComNet Ericsson Panther 600P Speaker Replacement, Locate the release button.: paso 1, imagen 2 de 3 ComNet Ericsson Panther 600P Speaker Replacement, Locate the release button.: paso 1, imagen 3 de 3
    • Look for the release button on the back of the radio.
    • Press the button and pull down on the battery at the same time. The battery will come free.
  2. ComNet Ericsson Panther 600P Speaker Replacement, Antenna: paso 2, imagen 1 de 1
    • Twist the antenna counter-clockwise to unscrew it from the antenna jack.
  3. ComNet Ericsson Panther 600P Speaker Replacement, Dials: paso 3, imagen 1 de 1
    • Pull up on the dials to remove them from the underlying pegs.
  4. ComNet Ericsson Panther 600P Speaker Replacement, Exterior Case: paso 4, imagen 1 de 3 ComNet Ericsson Panther 600P Speaker Replacement, Exterior Case: paso 4, imagen 2 de 3 ComNet Ericsson Panther 600P Speaker Replacement, Exterior Case: paso 4, imagen 3 de 3
    • Using a T15 Torx screwdriver, unscrew the two screws.
    • Using a plastic opening tool, pry the internal case from the external case.
  5. ComNet Ericsson Panther 600P Speaker Replacement, Speaker: paso 5, imagen 1 de 2 ComNet Ericsson Panther 600P Speaker Replacement, Speaker: paso 5, imagen 2 de 2
    • Locate the device's speaker inside the front panel of the exterior case.
    • Locate the display and speaker stabilizer.
    • Lift the stabilizer up from the bottom and pull the stabilizer out of case.
  6. ComNet Ericsson Panther 600P Speaker Replacement: paso 6, imagen 1 de 3 ComNet Ericsson Panther 600P Speaker Replacement: paso 6, imagen 2 de 3 ComNet Ericsson Panther 600P Speaker Replacement: paso 6, imagen 3 de 3
    • Locate the two 3.75mm screws holding the speaker to the exterior case.
    • Using a T15 Torx screwdriver, unscrew the 3.75mm screws.
  7. ComNet Ericsson Panther 600P Speaker Replacement: paso 7, imagen 1 de 2 ComNet Ericsson Panther 600P Speaker Replacement: paso 7, imagen 2 de 2
    • Lift up on the bottom of the speaker to detach the speaker.
    • Pull the speaker out of the case.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 184
