Saltar al contenido principal
ComNet Ericsson Panther 600P Display Replacement
Qué necesitas
  1. ComNet Ericsson Panther 600P Display Replacement, Locate the release button.: paso 1, imagen 1 de 3 ComNet Ericsson Panther 600P Display Replacement, Locate the release button.: paso 1, imagen 2 de 3 ComNet Ericsson Panther 600P Display Replacement, Locate the release button.: paso 1, imagen 3 de 3
    • Look for the release button on the back of the radio.
    • Press the button and pull down on the battery at the same time. The battery will come free.
  2. ComNet Ericsson Panther 600P Display Replacement, Antenna: paso 2, imagen 1 de 1
    • Twist the antenna counter-clockwise to unscrew it from the antenna jack.
  3. ComNet Ericsson Panther 600P Display Replacement, Dials: paso 3, imagen 1 de 1
    • Pull up on the dials to remove them from the underlying pegs.
  4. ComNet Ericsson Panther 600P Display Replacement, Exterior Case: paso 4, imagen 1 de 3 ComNet Ericsson Panther 600P Display Replacement, Exterior Case: paso 4, imagen 2 de 3 ComNet Ericsson Panther 600P Display Replacement, Exterior Case: paso 4, imagen 3 de 3
    • Using a T15 Torx screwdriver, unscrew the two screws.
    • Using a plastic opening tool, pry the internal case from the external case.
  5. ComNet Ericsson Panther 600P Display Replacement, Front Case - Internal: paso 5, imagen 1 de 3 ComNet Ericsson Panther 600P Display Replacement, Front Case - Internal: paso 5, imagen 2 de 3 ComNet Ericsson Panther 600P Display Replacement, Front Case - Internal: paso 5, imagen 3 de 3
    • Using the plastic opening tool, pry the case apart.
  6. ComNet Ericsson Panther 600P Display Replacement, Ribbon: paso 6, imagen 1 de 2 ComNet Ericsson Panther 600P Display Replacement, Ribbon: paso 6, imagen 2 de 2
    • The keypad chip is attached to the motherboard by a ribbon.
    • Pull ribbon with tweezers to detach from back panel.
  7. ComNet Ericsson Panther 600P Display Replacement, Screen: paso 7, imagen 1 de 3 ComNet Ericsson Panther 600P Display Replacement, Screen: paso 7, imagen 2 de 3 ComNet Ericsson Panther 600P Display Replacement, Screen: paso 7, imagen 3 de 3
    • Screen will be attached by a ribbon.
    • Pull screen up and away from motherboard to detach.
Conclusión
Daniel
Miembro Desde 01/13/15
109 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 209
