Saltar al contenido principal
Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement
Qué necesitas
  1. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Battery: paso 1, imagen 1 de 2 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Battery: paso 1, imagen 2 de 2
    • Carefully turn the lantern upside down.
    • Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
  2. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: paso 2, imagen 1 de 1
    • Carefully pull the bottom of the lantern to remove the base from the device.
  3. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: paso 3, imagen 1 de 2 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: paso 3, imagen 2 de 2
    • Gently pull the battery out of the slot and away from the base.
    • The battery may be held into place by adhesive strips.
  4. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: paso 4, imagen 1 de 3 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: paso 4, imagen 2 de 3 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: paso 4, imagen 3 de 3
    • Carefully detach the negative wire from the battery terminal first.
    • Next, detach the positive wire from the battery terminal.
  5. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Main Power Board: paso 5, imagen 1 de 2 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Main Power Board: paso 5, imagen 2 de 2
    • Remove the single 1.2 mm Phillips #1 screw on the bottom of the lantern.
    • Remove the plastic barrier.
  6. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: paso 6, imagen 1 de 2 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: paso 6, imagen 2 de 2
    • Unscrew the single 1.2 mm Phillips #1 screw holding the motherboard to the plastic lantern housing.
  7. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: paso 7, imagen 1 de 3 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: paso 7, imagen 2 de 3 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: paso 7, imagen 3 de 3
    • Gently grab the main board by the exposed PCB.
    • Pull the main board straight out of the housing.
Conclusión
Mathew Merrick
Miembro Desde 09/17/18
169 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 559
