Introducción
Is your switch unable to move due to a foreign liquid? Does the switch feel like its seated improperly? Check out this guide on removing and replacing the switch.
Qué necesitas
Carefully turn the lantern upside down.
Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
Remove the single 1.2 mm Phillips #1 screw on the bottom of the lantern.
Remove the plastic barrier.
Remove the switch by pushing down on the ends while simultaneously pulling it out of the slot.
