Saltar al contenido principal
Coleman Rechargeable Fluorescent Twin Tube Battery Replacement
Qué necesitas
  1. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement, Battery: paso 1, imagen 1 de 2 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement, Battery: paso 1, imagen 2 de 2
    • Carefully turn the lantern upside down.
    • Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
  2. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: paso 2, imagen 1 de 1
    • Carefully pull the bottom of the lantern to remove the base from the device.
  3. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: paso 3, imagen 1 de 2 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: paso 3, imagen 2 de 2
    • Gently pull the battery out of the slot and away from the base.
    • The battery may be held into place by adhesive strips.
  4. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: paso 4, imagen 1 de 3 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: paso 4, imagen 2 de 3 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: paso 4, imagen 3 de 3
    • Carefully detach the negative wire from the battery terminal first.
    • Next, detach the positive wire from the battery terminal.
Conclusión
Sean
Miembro Desde 09/17/18
265 Reputación
2 Guías creadas
Equipo
Un comentario
Sean, I’m facing a dead battery in my Coleman twin tube fluorescent lantern also. Your directions are spot on except my battery seems to be glued in with super glue! I’ve tried a heat gun and all my strength but my battery won’t come loose. I find it hard to pry under the battery because of the shape of the plastic partitions around the battery. How did you get the battery unstuck?
BilMcKelvy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 20
Ultimos 30 días: 87
Todo El Tiempo: 4,602
