Saltar al contenido principal
ColecoVision Controller Port Replacement
Qué necesitas
  1. ColecoVision Controller Port Replacement, Controller Port: paso 1, imagen 1 de 1
    • Flip the ColecoVision over with the pegs facing the ceiling.
    • Remove the eight 15mm screws holding the bottom of the ColecoVision in place using the Phillips #1 screwdriver.
  2. ColecoVision Controller Port Replacement: paso 2, imagen 1 de 2 ColecoVision Controller Port Replacement: paso 2, imagen 2 de 2
    • Carefully remove the bottom of the ColecoVision out of the top.
    • I would recommend running a metal spudger along the rim of the case to remove the bottom.
  3. ColecoVision Controller Port Replacement: paso 3, imagen 1 de 2 ColecoVision Controller Port Replacement: paso 3, imagen 2 de 2
    • Remove the two 15mm screws holding the casing in place using the Phillips #1 screwdriver.
    • Remove the casing and put it to the side.
  4. ColecoVision Controller Port Replacement: paso 4, imagen 1 de 2 ColecoVision Controller Port Replacement: paso 4, imagen 2 de 2
    • Remove the two 15mm screws on the motherboard with a Phillips #1 screwdriver.
    • Pull the entire motherboard towards the back of the system and carefully lift the entire motherboard.
  5. ColecoVision Controller Port Replacement: paso 5, imagen 1 de 3 ColecoVision Controller Port Replacement: paso 5, imagen 2 de 3 ColecoVision Controller Port Replacement: paso 5, imagen 3 de 3
    • Flip the motherboard over and locate the two controller ports.
    • Using a soldering iron, desolder the controller ports.
    • Refer to this soldering technique guide for reference.
    • After waiting for controller ports to cool down, flip motherboard back over and carefully lift controller ports to remove.
Conclusión
Bobby
Miembro Desde 10/17/18
380 Reputación
2 Guías creadas
Equipo
UW Tacoma, Team S1-G2, Rose Fall 2018 Miembro de UW Tacoma, Team S1-G2, Rose Fall 2018
UWT-ROSE-F18S1G2
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 833
