Saltar al contenido principal
Coby Kyros MID9742 Camera Module Replacement
Qué necesitas
  1. Coby Kyros MID9742 Camera Module Replacement, Outer Casing: paso 1, imagen 1 de 1
    • Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
  2. Coby Kyros MID9742 Camera Module Replacement: paso 2, imagen 1 de 1
    • Place the PH00 screwdriver and use it to remove the four 0.5 cm screws from each corner of the tablet.
  3. Coby Kyros MID9742 Camera Module Replacement: paso 3, imagen 1 de 1
    • Place a metal spudger tool in between the front and back panels of the tablet and begin to pry the base from the front panel by moving the metal tool around the perimeter of the tablet.
    • Note that clicking noises will be heard during this process, the panels are assembled well so it may take some force to separate the two panels.
    • Use caution while prying, do not stick the metal spudger in too far as it may damage internal components
  4. Coby Kyros MID9742 Camera Module Replacement, Camera Module: paso 4, imagen 1 de 1
    • Remove the two ribbon cables attached to the logic board.
  5. Coby Kyros MID9742 Camera Module Replacement: paso 5, imagen 1 de 1
    • Remove the tape covering the ribbon cables and remove the camera module.
Conclusión
Una persona más ha completado esta guía.
Jake
Miembro Desde 03/11/15
158 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 11
Todo El Tiempo: 200
