Introducción
If your Coby Kyros MID9042 is not producing clear audio (including distortion, static, or anything that sounds unpleasant) this guide can help you replace the speaker with a new one. This guide will require soldering skills and preciseness for steps requiring wiring and dewiring. It is recommended to solder in a soldering work-station or something similar.
For soldering and desoldering instruction please review the soldering page to ensure wiring connections are well soldered.
Qué necesitas
Remove the Anti-slip pads from all four corners of the back of the device.
Use Phillips #0 Precision screwdriver to remove the four screws from the back cover (screws are about 1/8'').
Desolder the red and black speaker wires from the circuit board. Cómo soldar y desoldar conexiones
Gently remove the speakers from the tablet.
When replacing the speaker, remember the red wire connects to positive and the black wire connects to negative.
