Saltar al contenido principal
Coby Kyros MID7125 Speaker Replacement
Qué necesitas
  1. Coby Kyros MID7125 Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Use opening too to make small opening in the side of the device.
    • Use plastic opening tool to pry the rest of the panel off.
  2. Coby Kyros MID7125 Speaker Replacement: paso 2, imagen 1 de 1
    • Once inside the device, locate the speakers on the inside of the back panel.
  3. Coby Kyros MID7125 Speaker Replacement: paso 3, imagen 1 de 1
    • Use spudger to pry one speaker up off of the back panel.
  4. Coby Kyros MID7125 Speaker Replacement: paso 4, imagen 1 de 1
    • Desolder the soldering points that connect the speaker to the motherboard.
  5. Coby Kyros MID7125 Speaker Replacement: paso 5, imagen 1 de 1
    • Use a soldering iron to solder the wires of the new speaker to the motherboard.
    • Make sure, when soldering, to connect the red wire to the red and the black wire to the black.
  6. Coby Kyros MID7125 Speaker Replacement: paso 6, imagen 1 de 1
    • Click the new speaker into the spot where you removed the old speaker.
    • Follow steps 2-6 for the other speaker. Snap in back panel to put device back together.
Conclusión
Nicole Connelly
Miembro Desde 10/20/16
1 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 5-2, Martin Fall 2016 Miembro de UMass Dartmouth, Team 5-2, Martin Fall 2016
UMASSD-MARTIN-F16S5G2
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 136
