Saltar al contenido principal
Coby Kyros MID7125 Battery Replacement
Qué necesitas
  1. Coby Kyros MID7125 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Use iFixit plastic opening tool to make small opening in the side of the device, and continue opening back panel.
  2. Coby Kyros MID7125 Battery Replacement: paso 2, imagen 1 de 1
    • Locate battery. The battery is the silver coated square shaped device on the top of the motherboard.
  3. Coby Kyros MID7125 Battery Replacement: paso 3, imagen 1 de 1
    • There is a small ribbon cable located under the battery. running from the volume buttons underneath the batter to main logic board.
  4. Coby Kyros MID7125 Battery Replacement: paso 4, imagen 1 de 1
    • Knowing the location the ribbon cable, use plastic spudger to pry off battery.
  5. Coby Kyros MID7125 Battery Replacement: paso 5, imagen 1 de 1
    • After the battery is free from the logic board, find the positive and negative wires that connect the battery to the motherboard
  6. Coby Kyros MID7125 Battery Replacement: paso 6, imagen 1 de 1
    • Using a soldering gun, heat up both soldering points.
    • Remove wires from logic board
    • Clean up soldering joints with a desoldering sucker
    • Solder the new battery wires to the same soldering points as the old battery
    • Reverse steps 1-5 to put device back together
Conclusión
Una persona más ha completado esta guía.
Ryan
Miembro Desde 10/20/16
108 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 5-2, Martin Fall 2016 Miembro de UMass Dartmouth, Team 5-2, Martin Fall 2016
UMASSD-MARTIN-F16S5G2
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 364
