Saltar al contenido principal
Coby Kyros MID7024 Back Cover Replacement
Qué necesitas
  1. Coby Kyros MID7024 Back Cover Replacement, Back Cover: paso 1, imagen 1 de 2 Coby Kyros MID7024 Back Cover Replacement, Back Cover: paso 1, imagen 2 de 2
    • Begin by ensuring that the device is powered off.
    • To replace the back cover of the device you must pry it open using the access points. One is located on the top of the device above the camera and the other is on the bottom left hand side.
    • Use the spudger to pry at the access points to open the device.
  2. Coby Kyros MID7024 Back Cover Replacement: paso 2, imagen 1 de 3 Coby Kyros MID7024 Back Cover Replacement: paso 2, imagen 2 de 3 Coby Kyros MID7024 Back Cover Replacement: paso 2, imagen 3 de 3
    • Once the back cover begins to separate from the body of the device continue working the spudger around the perimeter of the device until the back cover is free.
    • You will hear some popping and cracking noises as you pry open the device. These sounds are the internal clips coming apart.
    • Once the back cover is free from the body of the device, open both sides like a book, placing them flat on the table as shown. Be sure to pay attention to the speaker wires that hold the two pieces together.
  3. Coby Kyros MID7024 Back Cover Replacement: paso 3, imagen 1 de 3 Coby Kyros MID7024 Back Cover Replacement: paso 3, imagen 2 de 3 Coby Kyros MID7024 Back Cover Replacement: paso 3, imagen 3 de 3
    • This step is only necessary if you intend to repair or replace the back cover and/or speakers of the device.
    • In order to replace the back cover you must remove the speakers. Place the Spudger under the plastic frame of the speaker as shown. Pry up, popping the corners of the speakers out of of their bracket and lift the speaker out.
    • Be sure not to pull on the speaker's wires or body too hard as you may damage them.
Conclusión
Kyle Williams
Miembro Desde 03/21/16
246 Reputación
2 Guías creadas
Equipo
Clemson, Team 6-3, Benson Spring 2016 Miembro de Clemson, Team 6-3, Benson Spring 2016
CLEM-BENSON-S16S6G3
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 303
