Saltar al contenido principal
Coby KYROS MID7125 Motherboard Replacement
Qué necesitas
  1. Coby KYROS MID7125 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Use iFixit plastic opening tool to make small opening in the side of the device, and continue opening back panel
  2. Coby KYROS MID7125 Motherboard Replacement: paso 2, imagen 1 de 3 Coby KYROS MID7125 Motherboard Replacement: paso 2, imagen 2 de 3 Coby KYROS MID7125 Motherboard Replacement: paso 2, imagen 3 de 3
    • There are 5 ribbon cables connected to the motherboard. Two of these cables are clipped on and one is soldered on. Remove the 4 ribbon cables you can clip off using the plastic spudger
    • For large ribbon cable use plastic spudger or your fingers to release ribbon cable clip by pulling the black edges down and pulling ribbon cable out.
    • For ribbon cable on the left side, flip up black hinge to remove ribbon cable
    • Desolder fifth ribbon cable with soldering station.
  3. Coby KYROS MID7125 Motherboard Replacement: paso 3, imagen 1 de 3 Coby KYROS MID7125 Motherboard Replacement: paso 3, imagen 2 de 3 Coby KYROS MID7125 Motherboard Replacement: paso 3, imagen 3 de 3
    • Desolder 2 speaker wires
    • Desolder antenna wire
    • Desolder microphone wire
    • Remove all wires you just desoldered.
  4. Coby KYROS MID7125 Motherboard Replacement: paso 4, imagen 1 de 1
    • Desolder the battery wires.
    • If soldering is new to you, then check out this useful guide on soldering and desoldering connections.
    • Remove the battery.
  5. Coby KYROS MID7125 Motherboard Replacement: paso 5, imagen 1 de 1
    • Unscrew 4 screws connecting around mother board using the J0 Phillips head screwdriver.
  6. Coby KYROS MID7125 Motherboard Replacement: paso 6, imagen 1 de 2 Coby KYROS MID7125 Motherboard Replacement: paso 6, imagen 2 de 2
    • Use plastic spudger to take off motherboard by lifting off right hand side and pulling sideways.
Conclusión
Nicole Connelly
Miembro Desde 10/20/16
1 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 5-2, Martin Fall 2016 Miembro de UMass Dartmouth, Team 5-2, Martin Fall 2016
UMASSD-MARTIN-F16S5G2
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 278
