Saltar al contenido principal
Coby DVD209 The bottom portion of the DVD player Replacement
Qué necesitas
  1. Coby DVD209 The bottom portion of the DVD player Replacement, The bottom portion of the DVD player: paso 1, imagen 1 de 3 Coby DVD209 The bottom portion of the DVD player Replacement, The bottom portion of the DVD player: paso 1, imagen 2 de 3 Coby DVD209 The bottom portion of the DVD player Replacement, The bottom portion of the DVD player: paso 1, imagen 3 de 3
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Coby DVD209 The bottom portion of the DVD player Replacement: paso 2, imagen 1 de 3 Coby DVD209 The bottom portion of the DVD player Replacement: paso 2, imagen 2 de 3 Coby DVD209 The bottom portion of the DVD player Replacement: paso 2, imagen 3 de 3
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. Coby DVD209 The bottom portion of the DVD player Replacement: paso 3, imagen 1 de 3 Coby DVD209 The bottom portion of the DVD player Replacement: paso 3, imagen 2 de 3 Coby DVD209 The bottom portion of the DVD player Replacement: paso 3, imagen 3 de 3
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
Conclusión
Kyle VanAllen
Miembro Desde 01/20/12
70 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 10-36, Amido Winter 2012 Miembro de Cal Poly, Team 10-36, Amido Winter 2012
CPSU-AMIDO-W12S10G36
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 12
Todo El Tiempo: 323
