Qué necesitas
Press the eject button to view the laser inside.
Using the blue plastic tool and the tweezers, remove the ribbon cable.
Position the DVD player so that the power and AVI ports are facing you.
Pull the white cable with the blue adapters off of the circuit boards.
Using the plastic opening tool and your finger, push on the black tab on the inner part of the power port and lift the bottom outer portion of the power port with the plastic opening tool simultaneously.
Lift the power port out of the its slot.
On the circuit board with the Power Port, de-solder the circled areas on the back to remove the Power port.
Una persona más ha completado esta guía.
