Saltar al contenido principal
Coby DVD209 4-Pin Ribbon Cable Replacement
Qué necesitas
  1. Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: paso 1, imagen 1 de 3 Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: paso 1, imagen 2 de 3 Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: paso 1, imagen 3 de 3
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Coby DVD209 4-Pin Ribbon Cable Replacement: paso 2, imagen 1 de 3 Coby DVD209 4-Pin Ribbon Cable Replacement: paso 2, imagen 2 de 3 Coby DVD209 4-Pin Ribbon Cable Replacement: paso 2, imagen 3 de 3
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. Coby DVD209 4-Pin Ribbon Cable Replacement: paso 3, imagen 1 de 3 Coby DVD209 4-Pin Ribbon Cable Replacement: paso 3, imagen 2 de 3 Coby DVD209 4-Pin Ribbon Cable Replacement: paso 3, imagen 3 de 3
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  4. Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: paso 4, imagen 1 de 3 Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: paso 4, imagen 2 de 3 Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: paso 4, imagen 3 de 3
    • Position the DVD player so that the power and AVI ports are facing you.
    • Pull the white cable with the blue adapters off of the circuit boards.
Conclusión
Una persona más ha completado esta guía.
Yufay Chow
Miembro Desde 01/23/12
92 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 10-36, Amido Winter 2012 Miembro de Cal Poly, Team 10-36, Amido Winter 2012
CPSU-AMIDO-W12S10G36
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,007
