Introducción
The quick guide to removing the antenna to the Cobra MR HH350 FLT radio.
To remove the Antenna to the Cobra MR HH350 FLT radio, you have to turn it counterclockwise until the grooves for the antenna are visible. After they become fully visible, you will be able to pull it away from the radio.
To reattach the antenna, line up the grooves with the hole at the top of the radio and twist it clockwise until the grooves are no longer visible.
