Saltar al contenido principal
Cobra 29 LTD Classic Outer Cover Replacement
Qué necesitas
  1. Cobra 29 LTD Classic Outer Cover Replacement, Power Cable: paso 1, imagen 1 de 2 Cobra 29 LTD Classic Outer Cover Replacement, Power Cable: paso 1, imagen 2 de 2
    • Turn the power switch, the leftmost knob, counterclockwise to off.
  2. Cobra 29 LTD Classic Outer Cover Replacement: paso 2, imagen 1 de 2 Cobra 29 LTD Classic Outer Cover Replacement: paso 2, imagen 2 de 2
    • Turn the device around and firmly pull the power cable plug to remove it from the radio.
  3. Cobra 29 LTD Classic Outer Cover Replacement, Antenna Cable: paso 3, imagen 1 de 2 Cobra 29 LTD Classic Outer Cover Replacement, Antenna Cable: paso 3, imagen 2 de 2
    • Unscrew the securing cap counterclockwise from the antenna connector.
  4. Cobra 29 LTD Classic Outer Cover Replacement: paso 4, imagen 1 de 2 Cobra 29 LTD Classic Outer Cover Replacement: paso 4, imagen 2 de 2
    • Gently pull the antenna cable to remove it from the back of the radio.
  5. Cobra 29 LTD Classic Outer Cover Replacement, Microphone: paso 5, imagen 1 de 2 Cobra 29 LTD Classic Outer Cover Replacement, Microphone: paso 5, imagen 2 de 2
    • Unscrew the cap counterclockwise on the microphone plug to disconnect the cable.
  6. Cobra 29 LTD Classic Outer Cover Replacement: paso 6, imagen 1 de 1
    • Gently unplug the microphone plug.
  7. Cobra 29 LTD Classic Outer Cover Replacement, Outer Cover: paso 7, imagen 1 de 2 Cobra 29 LTD Classic Outer Cover Replacement, Outer Cover: paso 7, imagen 2 de 2
    • Unscrew the top four 6.0mm Phillips head screws counterclockwise on the left and right side of the device using a #1 Phillips head screwdriver.
  8. Cobra 29 LTD Classic Outer Cover Replacement: paso 8, imagen 1 de 3 Cobra 29 LTD Classic Outer Cover Replacement: paso 8, imagen 2 de 3 Cobra 29 LTD Classic Outer Cover Replacement: paso 8, imagen 3 de 3
    • Gently life and remove the top cover.
  9. Cobra 29 LTD Classic Outer Cover Replacement: paso 9, imagen 1 de 3 Cobra 29 LTD Classic Outer Cover Replacement: paso 9, imagen 2 de 3 Cobra 29 LTD Classic Outer Cover Replacement: paso 9, imagen 3 de 3
    • Gently set down on a hard, flat, non-conductive surface to minimize risk of shock or breaking your radio.
    • Carefully flip the radio over.
  10. Cobra 29 LTD Classic Outer Cover Replacement: paso 10, imagen 1 de 2 Cobra 29 LTD Classic Outer Cover Replacement: paso 10, imagen 2 de 2
    • Unscrew the four 6.0mm Phillips head screws counterclockwise on the left and right side of the device that connect the remaining cover, using a #1 Phillips head screwdriver.
  11. Cobra 29 LTD Classic Outer Cover Replacement: paso 11, imagen 1 de 3 Cobra 29 LTD Classic Outer Cover Replacement: paso 11, imagen 2 de 3 Cobra 29 LTD Classic Outer Cover Replacement: paso 11, imagen 3 de 3
    • Watch out for the wires connected to the speaker. These short wires will not allow you to move the cover very far.
    • Gently lift and remove the case cover.
Conclusión
2 personas más completaron esta guía.
Chase
Miembro Desde 10/20/13
267 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 11-37, Amido Fall 2013 Miembro de Cal Poly, Team 11-37, Amido Fall 2013
CPSU-AMIDO-F13S11G37
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 16
Todo El Tiempo: 1,651
