Saltar al contenido principal
Clipper Lighter Flint Replacement
Qué necesitas
  1. Clipper Lighter Flint Replacement, Flint: paso 1, imagen 1 de 3 Clipper Lighter Flint Replacement, Flint: paso 1, imagen 2 de 3 Clipper Lighter Flint Replacement, Flint: paso 1, imagen 3 de 3
    • Purchase flint for lighters - should look cylindrical in nature and small.
  2. Clipper Lighter Flint Replacement: paso 2, imagen 1 de 2 Clipper Lighter Flint Replacement: paso 2, imagen 2 de 2
    • Pull upwards on the spark wheel to remove it from the lighter.
  3. Clipper Lighter Flint Replacement: paso 3, imagen 1 de 1
    • Flip the mechanism upside down so that the groove is facing up.
  4. Clipper Lighter Flint Replacement: paso 4, imagen 1 de 2 Clipper Lighter Flint Replacement: paso 4, imagen 2 de 2
    • Use the top of the lighter housing to twist the cap loose.
    • Set aside the lighter once it becomes loose enough to do it by hand.
  5. Clipper Lighter Flint Replacement: paso 5, imagen 1 de 2 Clipper Lighter Flint Replacement: paso 5, imagen 2 de 2
    • Pull on the cap and the spring will come out with it.
  6. Clipper Lighter Flint Replacement: paso 6, imagen 1 de 2 Clipper Lighter Flint Replacement: paso 6, imagen 2 de 2
    • Flip the mechanism and tap on the bottom so that the old flint falls out if there is any left.
    • Use a hard surface if necessary.
  7. Clipper Lighter Flint Replacement: paso 7, imagen 1 de 1
    • Take a new flint and drop it down the tube.
Conclusión
7 personas más completaron esta guía.
Daniel Gherman
Miembro Desde 01/18/22
313 Reputación
1 Guía escrita
Equipo
5 comentarios
thank you very much for the clear instruction, it was very helpful.
Daniel Kalani - Contestar
SO Thankful 4this! Wish much more could stay out of landfills!! We're such a wasteful country!!
deborah Smith - Contestar
Easier than I thought...cool dude
Teresa Sigerson - Contestar
I've got the metal Clipper with a cap over the wheel (EU version). Instead of flicking the wheel with your thumb, you press down on the cap/switch. Now my flint's exhausted and I can't figure out how to remove the cap to change it! Does anyone know?
cherrya.facebook - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 69
Ultimos 7 días: 383
Ultimos 30 días: 1,783
Todo El Tiempo: 17,427
