Saltar al contenido principal
Cleaning the Ulco Integrus PSV
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
  1. Cleaning the Ulco Integrus PSV, Cleaning the Ulco Integrus PSV: paso 1, imagen 1 de 2 Cleaning the Ulco Integrus PSV, Cleaning the Ulco Integrus PSV: paso 1, imagen 2 de 2
    • Absorber
    • Loosen the knurled screws and remove the clear lid.
  2. Cleaning the Ulco Integrus PSV: paso 2, imagen 1 de 1
    • Remove the silicone shutters by gently lifting from the base, NOT from the flaps.
  3. Cleaning the Ulco Integrus PSV: paso 3, imagen 1 de 1
    • To release and remove the canister(s), undo the handle latch by turning sideways.
  4. Cleaning the Ulco Integrus PSV: paso 4, imagen 1 de 1
    • Push the release handle down to vertical until canisters are free.
  5. Cleaning the Ulco Integrus PSV: paso 5, imagen 1 de 1
    • Push canister(s) down then out of the cradle. Then dispose of the used soda lime (see suppliers recommended procedure for disposal of soda lime).
    • Wash all the absorber components. Do NOT use caustic cleaning fluids.
    • The Canister(s) and silicone shutters can be autoclaved.
    • The Absorber head can be put through a washer at 80 deg.C
    • Dry thoroughly before assembly, low pressure warm air should be passed through the head by attaching a hose to the expiratory port of the absorber.
  6. Cleaning the Ulco Integrus PSV: paso 6, imagen 1 de 2 Cleaning the Ulco Integrus PSV: paso 6, imagen 2 de 2
    • Bellows Assembly
    • Loosen the four knurled screws (1) and remove the bellows canister.
  7. Cleaning the Ulco Integrus PSV: paso 7, imagen 1 de 1
    • Remove the bellows assembly by rotating counter-clockwise. The bellows canister may be washed or autoclaved.
  8. Cleaning the Ulco Integrus PSV: paso 8, imagen 1 de 1
    • The base disk (mushroom) should be removed from the bellows assembly before washing. Pull the latex-free rubber bag from the delrin base disk. The bellows may be washed or autoclaved. The base component (mushroom) should not be autoclaved but can be put through a washer at 80°C.
    • Dry all components thoroughly before re-assembly.
    • Low pressure warm air should be passed through the absorber head by attaching a hose to the scavenge port
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team S7-G13, Paton Spring 2020 Miembro de Cal Poly, Team S7-G13, Paton Spring 2020
CPSU-PATON-S20S7G13
Miembros de 3
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 96
