Saltar al contenido principal
Cleaning the Fan Blades
Qué necesitas
  1. Cleaning the Fan Blades, PCB (Printed Circuit Board): paso 1, imagen 1 de 1
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
  2. Cleaning the Fan Blades: paso 2, imagen 1 de 1
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
  3. Cleaning the Fan Blades: paso 3, imagen 1 de 1
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
  4. Cleaning the Fan Blades: paso 4, imagen 1 de 1
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
  5. Cleaning the Fan Blades: paso 5, imagen 1 de 2 Cleaning the Fan Blades: paso 5, imagen 2 de 2
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
  6. Cleaning the Fan Blades, Fan Blades: paso 6, imagen 1 de 1
    • Follow steps 1-4 to remove the front, back, and top covers of the fan to reach the fan blades.
    • Use a cloth to clean off dust clogged in between the fan blades.
Conclusión
Una persona más ha completado esta guía.
Vivian Fong
Miembro Desde 09/26/12
97 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 15-46, Forte Fall 2012 Miembro de Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 26
Todo El Tiempo: 10,707
