Introducción
How to disassemble the device to access the sensor, clean it, then reassemble.
Qué necesitas
Remove the 4 Hex screws surrounding the protective case.
Note: The two hex screws closest to the front lens are decorative, and cannot be removed.
Remove the two screws from the opposite side of the battery compartment.
On top, next to the GPS unit, remove the top screw
On the bottom remove the two screws next to the tripod mount
All the screws surrounding the protective aluminum housing should now be removed. Using a spudger or other flat tool, carefully work your way around this housing, separating it from the body.
This is where you need to be the most careful.
Unscrew the three screws securing the image sensor
Carefully remove the image sensor
A rubber gasket and protective lens separate between the sensor assembly and sensor itself.
Turn the assembly over to remove the glass and gasket.
Spray the gasket, glass, and sensor with canned air.
Reassemble the sensor, placing the glass in the assembly. It should fit snugly. On top of the, place the gasket, square side towards the glass, with the oval piece facing where the sensor was.
When reattaching the sensor, it may help to have the screws already in the hole then hovering slowly back in to place. Be very careful not to let the sensor touch anything. Screw down the sensor, then follow these steps in reverse order to reassemble.
If your pictures were blurry this may help, it certainly did for me.
Una persona más ha completado esta guía.
