Saltar al contenido principal
Cleaning Debris from Flywheel Screen
Qué necesitas
  1. Cleaning Debris from Flywheel Screen, Cleaning Debris from Flywheel Screen: paso 1, imagen 1 de 3 Cleaning Debris from Flywheel Screen, Cleaning Debris from Flywheel Screen: paso 1, imagen 2 de 3 Cleaning Debris from Flywheel Screen, Cleaning Debris from Flywheel Screen: paso 1, imagen 3 de 3
    • Ensure the engine is off and cooled down before starting this guide.
    • Using a 5/16" socket or wrench, remove the three bolts holding the plastic cover on to the engine.
    • Lift away the plastic cover. Note that the starter is attached to the cover and will come off with it.
  2. Cleaning Debris from Flywheel Screen: paso 2, imagen 1 de 2 Cleaning Debris from Flywheel Screen: paso 2, imagen 2 de 2
    • Using compressed air or a rag, clean debris from the flywheel.
Conclusión
2 personas más completaron esta guía.
Ethan Narad
Miembro Desde 04/19/18
529 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S25-G15, Maness Spring 2018 Miembro de Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 17
Todo El Tiempo: 950
