Esta traducción podría no reflejar los cambios más recientes añadidos a la guía de referencia. Ayúdanos a actualizar la traducción o revisa la guía original.
Introducción
The coffee spout is a part that is rarely cleaned and is not cleaned efficiently by the cleaning program.
This guide will show you how to easily disassemble and manually clean it.
These instructions may also help with other Siemens/Bosch models and with coffee makers from Nivona, Melitta, and Miele—they have a very similar design.
Qué necesitas
Now slide the spudger/screwdriver between the plastic cap and the cover and gently pry in the direction of the coffee machine. This pushes the cover over the barb.
Grab the cover by the sides and pull it up. This is often very difficult, so pull it hard but not excessively.
Work through the steps in reverse order to reassemble your device.
Una persona más ha completado esta guía.
Un agradecimiento especial a estos traductores:
83%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
