Saltar al contenido principal
Introducción
This guide shows how to remove and replace the blower housing for a Clarke Floor Sander 07014A.
  1. Clarke Floor Sander 07014A 2012 Blower Housing Replacement, Dust Bag: paso 1, imagen 1 de 2 Clarke Floor Sander 07014A 2012 Blower Housing Replacement, Dust Bag: paso 1, imagen 2 de 2
    • Before you begin, be sure that the sander is unplugged and powered off.
    • Twist and pull the dust bag collar to disconnect it from the elbow pipe.
    • Remove the dust bag.
  2. Clarke Floor Sander 07014A 2012 Blower Housing Replacement, Blower Housing: paso 2, imagen 1 de 2 Clarke Floor Sander 07014A 2012 Blower Housing Replacement, Blower Housing: paso 2, imagen 2 de 2
    • Peel the rubber sleeve down from the elbow pipe to reveal the pipe socket.
  3. Clarke Floor Sander 07014A 2012 Blower Housing Replacement: paso 3, imagen 1 de 3 Clarke Floor Sander 07014A 2012 Blower Housing Replacement: paso 3, imagen 2 de 3 Clarke Floor Sander 07014A 2012 Blower Housing Replacement: paso 3, imagen 3 de 3
    • Grasp the elbow pipe with your hands and pull up while twisting to disconnect it from the blower housing.
    • Remove the elbow pipe.
  4. Clarke Floor Sander 07014A 2012 Blower Housing Replacement: paso 4, imagen 1 de 3 Clarke Floor Sander 07014A 2012 Blower Housing Replacement: paso 4, imagen 2 de 3 Clarke Floor Sander 07014A 2012 Blower Housing Replacement: paso 4, imagen 3 de 3
    • Twist and pull to disconnect both suction hoses from the blower housing.
  5. Clarke Floor Sander 07014A 2012 Blower Housing Replacement: paso 5, imagen 1 de 2 Clarke Floor Sander 07014A 2012 Blower Housing Replacement: paso 5, imagen 2 de 2
    • Remove the four 22mm long Phillips screws around the side of the blower housing.
  6. Clarke Floor Sander 07014A 2012 Blower Housing Replacement: paso 6, imagen 1 de 2 Clarke Floor Sander 07014A 2012 Blower Housing Replacement: paso 6, imagen 2 de 2
    • Lift the blower housing upwards and slide it off of the blower assembly.
    • Remove the blower housing.
Conclusión
2 personas más completaron esta guía.
Arthur Shi
Miembro Desde 03/01/18
207,457 Reputación
436 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
146 Miembros
16,090 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 27
Todo El Tiempo: 909
