Introducción
When you own a watch for an extended amount of time there is going to be wear on the strap. Instead of buying a new watch you can simply replace the strap.
Qué necesitas
Flip your watch to the back.
Insert the small end with the bar between the fork. Press outwards; when you feel the pressure, pull up slowly.
Casi Terminas!
Replace the other strap by following the same instructions.
Conclusión
