Saltar al contenido principal
Cisco Meraki MC74-HW Sensor Cover Replacement
Qué necesitas
  1. Cisco Meraki MC74-HW Sensor Cover Replacement, Back Housing and Device Stand: paso 1, imagen 1 de 3 Cisco Meraki MC74-HW Sensor Cover Replacement, Back Housing and Device Stand: paso 1, imagen 2 de 3 Cisco Meraki MC74-HW Sensor Cover Replacement, Back Housing and Device Stand: paso 1, imagen 3 de 3
    • Extend the stand as far away as possible from the device.
    • Remove all four 3 mm Hex 2 screws from the stand.
    • A bit with a flexible extension may be needed to remove these screws.
  2. Cisco Meraki MC74-HW Sensor Cover Replacement: paso 2, imagen 1 de 2 Cisco Meraki MC74-HW Sensor Cover Replacement: paso 2, imagen 2 de 2
    • Lift the stand off the device.
  3. Cisco Meraki MC74-HW Sensor Cover Replacement: paso 3, imagen 1 de 3 Cisco Meraki MC74-HW Sensor Cover Replacement: paso 3, imagen 2 de 3 Cisco Meraki MC74-HW Sensor Cover Replacement: paso 3, imagen 3 de 3
    • Insert a plastic spudger between the back housing cover and the sensor cover piece.
    • Work your way slowly around the edges of the device until all the clips have been unclipped.
    • Do not insert any tool recklessly into the device or you might damage wires and connections.
  4. Cisco Meraki MC74-HW Sensor Cover Replacement: paso 4, imagen 1 de 2 Cisco Meraki MC74-HW Sensor Cover Replacement: paso 4, imagen 2 de 2
    • Separate the back housing cover from the device completely.
  5. Cisco Meraki MC74-HW Sensor Cover Replacement, Phone Sensor: paso 5, imagen 1 de 2 Cisco Meraki MC74-HW Sensor Cover Replacement, Phone Sensor: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Disconnect the ribbon from the phone sensor board using a pair of reverse tweezers.
    • Electronic ribbons are very fragile, so pull slowly to disconnect them.
  6. Cisco Meraki MC74-HW Sensor Cover Replacement: paso 6, imagen 1 de 3 Cisco Meraki MC74-HW Sensor Cover Replacement: paso 6, imagen 2 de 3 Cisco Meraki MC74-HW Sensor Cover Replacement: paso 6, imagen 3 de 3
    • Remove the two 1.2 mm screws holding the phone sensor using a Phillips #0 screwdriver.
    • Carefully lift the phone sensor to remove it from the device.
  7. Cisco Meraki MC74-HW Sensor Cover Replacement, Sensor Cover: paso 7, imagen 1 de 3 Cisco Meraki MC74-HW Sensor Cover Replacement, Sensor Cover: paso 7, imagen 2 de 3 Cisco Meraki MC74-HW Sensor Cover Replacement, Sensor Cover: paso 7, imagen 3 de 3
    • Remove the two 1.2 mm screws using a Phillips #0 screwdriver.
    • Remove the sensor cover.
Conclusión
Anthony Kairouz
Miembro Desde 10/18/21
253 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 1-5, Simcock Fall 2021 Miembro de UMass Dartmouth, Team 1-5, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G5
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 121
