Saltar al contenido principal
Cisco Meraki MC74-HW Back Housing and Device Stand Replacement
Qué necesitas
  1. Cisco Meraki MC74-HW Back Housing and Device Stand Replacement, Back Housing and Device Stand: paso 1, imagen 1 de 3 Cisco Meraki MC74-HW Back Housing and Device Stand Replacement, Back Housing and Device Stand: paso 1, imagen 2 de 3 Cisco Meraki MC74-HW Back Housing and Device Stand Replacement, Back Housing and Device Stand: paso 1, imagen 3 de 3
    • Extend the stand as far away as possible from the device.
    • Remove all four 3 mm Hex 2 screws from the stand.
    • A bit with a flexible extension may be needed to remove these screws.
  2. Cisco Meraki MC74-HW Back Housing and Device Stand Replacement: paso 2, imagen 1 de 2 Cisco Meraki MC74-HW Back Housing and Device Stand Replacement: paso 2, imagen 2 de 2
    • Lift the stand off the device.
  3. Cisco Meraki MC74-HW Back Housing and Device Stand Replacement: paso 3, imagen 1 de 3 Cisco Meraki MC74-HW Back Housing and Device Stand Replacement: paso 3, imagen 2 de 3 Cisco Meraki MC74-HW Back Housing and Device Stand Replacement: paso 3, imagen 3 de 3
    • Insert a plastic spudger between the back housing cover and the sensor cover piece.
    • Work your way slowly around the edges of the device until all the clips have been unclipped.
    • Do not insert any tool recklessly into the device or you might damage wires and connections.
  4. Cisco Meraki MC74-HW Back Housing and Device Stand Replacement: paso 4, imagen 1 de 2 Cisco Meraki MC74-HW Back Housing and Device Stand Replacement: paso 4, imagen 2 de 2
    • Separate the back housing cover from the device completely.
Conclusión
Anthony Kairouz
Miembro Desde 10/18/21
253 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 1-5, Simcock Fall 2021 Miembro de UMass Dartmouth, Team 1-5, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G5
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 194
