Qué necesitas
Use the Phillips #1 Screwdriver to remove the two screws on back side of the device.
1. Gently push the top cover of the router away from you.
2. Lift it up top cover from the bottom of the router.
3. Remove top cover from the device.
Use the Phillips #1 Screwdriver to remove the three screws on front side of the device.
1. Gently lift up inner metal shield from the bottom of the router.
2. Remove inner metal shield from the device (see the anchors on the picture).
1. Place your fingers on the levers at the two sides of the slot, and push open.
2. Firmly pull the release lever away from the module until the module pops up.
3. You can then remove the module from the module slot.
1. Use the Phillips #1 Screwdriver to remove the black screw.
2. Use the Phillips #1 Screwdriver to remove the silver screw as shown on picture.
Gently pull the module up to disconnect two connectors underneath.
Use the Phillips #1 Screwdriver to remove the two screws holding the motherboard.
1. Gently lift up the board to release plastic locks.
2. Gently pull the board away from backside panel (to release metal shielding locks around connectors).
3. Remove board from the case.
Una persona más ha completado esta guía.
