Saltar al contenido principal
Circuit Board Housing Removal
Qué necesitas
  1. Circuit Board Housing Removal, Battery: paso 1, imagen 1 de 2 Circuit Board Housing Removal, Battery: paso 1, imagen 2 de 2
    • Locate the horizontal grip located on the back cover of the phone.
    • Slide the back cover down and off of the phone.
  2. Circuit Board Housing Removal: paso 2, imagen 1 de 2 Circuit Board Housing Removal: paso 2, imagen 2 de 2
    • Insert a plastic opening tool into the battery release point located above the battery.
    • Pull outwards in order to release the battery.
  3. Circuit Board Housing Removal, Circuit Board Housing: paso 3, imagen 1 de 3 Circuit Board Housing Removal, Circuit Board Housing: paso 3, imagen 2 de 3 Circuit Board Housing Removal, Circuit Board Housing: paso 3, imagen 3 de 3
    • Locate the 5 screws holding the body of the phone together.
    • The top screw will have a plastic cover, remove it using tweezers.
    • Using a Philips head screwdriver, twist counterclockwise to remove the screws.
    • Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
  4. Circuit Board Housing Removal: paso 4, imagen 1 de 2 Circuit Board Housing Removal: paso 4, imagen 2 de 2
    • Lift the back cover starting at the bottom of the phone.
  5. Circuit Board Housing Removal: paso 5, imagen 1 de 2 Circuit Board Housing Removal: paso 5, imagen 2 de 2
    • Remove the back cover completely from the phone.
Conclusión
Equipo
Clemson, Team 14-7, Benson Fall 2013 Miembro de Clemson, Team 14-7, Benson Fall 2013
CLEM-BENSON-F13S14G7
3 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 14
Todo El Tiempo: 611
