Saltar al contenido principal
Cirago M9030 Screen Protector Replacement
Qué necesitas
  1. Cirago M9030 Screen Protector Replacement, Cover: paso 1, imagen 1 de 1
    • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
  2. Cirago M9030 Screen Protector Replacement: paso 2, imagen 1 de 1
    • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
    • Remove the warranty sticker across the bottom.
  3. Cirago M9030 Screen Protector Replacement: paso 3, imagen 1 de 2 Cirago M9030 Screen Protector Replacement: paso 3, imagen 2 de 2
    • Gently take the cover apart using your hands separating the top and bottom.
    • The outer shell is expected to easily come apart.
  4. Cirago M9030 Screen Protector Replacement, Hard Drive: paso 4, imagen 1 de 1
    • Make sure that the screen of the device is facing down.
  5. Cirago M9030 Screen Protector Replacement: paso 5, imagen 1 de 3 Cirago M9030 Screen Protector Replacement: paso 5, imagen 2 de 3 Cirago M9030 Screen Protector Replacement: paso 5, imagen 3 de 3
    • Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
    • Raise the bottom edge of the hard drive 15 degrees up from the device.
  6. Cirago M9030 Screen Protector Replacement: paso 6, imagen 1 de 3 Cirago M9030 Screen Protector Replacement: paso 6, imagen 2 de 3 Cirago M9030 Screen Protector Replacement: paso 6, imagen 3 de 3
    • Place fingers on the IDE connectors gently picking up and sliding the hard drive out from the IDE module.
  7. Cirago M9030 Screen Protector Replacement, IDE Connector: paso 7, imagen 1 de 2 Cirago M9030 Screen Protector Replacement, IDE Connector: paso 7, imagen 2 de 2
    • Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard located at the top.
  8. Cirago M9030 Screen Protector Replacement: paso 8, imagen 1 de 1
    • Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
  9. Cirago M9030 Screen Protector Replacement: paso 9, imagen 1 de 2 Cirago M9030 Screen Protector Replacement: paso 9, imagen 2 de 2
    • Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
    • Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
  10. Cirago M9030 Screen Protector Replacement: paso 10, imagen 1 de 1
    • Using the plastic opening tool, completely lift the ribbon off of the motherboard.
  11. Cirago M9030 Screen Protector Replacement: paso 11, imagen 1 de 2 Cirago M9030 Screen Protector Replacement: paso 11, imagen 2 de 2
    • Completely remove the IDE connector from the device.
    • The audio jack is attached to the IDE connector. Pull at a 45 degree angle from the audio jack.
  12. Cirago M9030 Screen Protector Replacement, Motherboard: paso 12, imagen 1 de 2 Cirago M9030 Screen Protector Replacement, Motherboard: paso 12, imagen 2 de 2
    • Using the plastic opening tool, wedge the tool underneath the top edge of the motherboard.
    • Completely remove the motherboard.
    • The motherboard should slide out easily.
  13. Cirago M9030 Screen Protector Replacement, Screen Protector: paso 13, imagen 1 de 1
    • Locate the plastic screen protector on the front cover.
  14. Cirago M9030 Screen Protector Replacement: paso 14, imagen 1 de 1
    • Grasping the sides of the cover, gently press on screen protector from the inside of the front cover to pop out the screen protector.
Conclusión
Una persona más ha completado esta guía.
Ryan Sutardji
Miembro Desde 06/29/12
171 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 1-4, Regan SU 2012 Miembro de Cal Poly, Team 1-4, Regan SU 2012
CPSU-REGAN-SU12S1G4
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 17
Todo El Tiempo: 934
